DXF file imports to Lasercad fine but bits missing in cutter
BazzaM
im importing to lasercad from turbocad and drawing is the same but when i up load to the cutter, bits are missing?
It imports to lasercad fine but is then different when on to machine screen?
Any ideas please??
Thanks Bazza
Any ideas please??
Thanks Bazza
mark seward
Re: DXF file imports to Lasercad fine but bits missing in cu
this is whats happening its not reading from laser cad to the lo-x7 and cutting as per the lo-x7 screen and not as per laser cad
I will post a newer version that may addressed the issue
BTW, try export to Illustrator FORMAT because It WORK Better On Cuttings. DXF is kind of troublesome for some Cad or version
BazzaM
When will you post the newer version Marco?Tech_Marco wrote:I will post a newer version that may addressed the issue
After lunch ....late for it
mark seward
hi marco tried to download the patch for the lo-x7 but asking for a username and password
how did you get that???
When you put the file on a USB stuck, place that in the display's USB-port and select the upgrade file in the menu.. No password request on my X7..
BTW when you didn't change anything, I suspect the user will be 111111 and the password probably 608..
mark seward
barry sent me the file as it just would not down load kept asking for password and username now got on memeroy stick and in cutter. gone to upgrade and now doing it but dont think its worked as tried to do file above and its just the same
mark seward
upgrade has not sorted problem
mark seward
it is now worse as a drawing that was working with an engraved part on has now lost that as well
