K40 front panel mount for DSP card by CorelDraw V12
Postby Tech_Marco » Thu Jul 18, 2013 9:29 am
I'm posting the DSP LCD control unit front panel layout for K40. Note that the screw hole may not be 100% alignment as the K40 is not 'quite' standard. You may edit yourself by using CorelDraw v12 or above version.
LaserFrontPanel CDR12.cdr
Download this file
(191.01 KiB) Downloaded 272 times
Re: K40 front panel mount for DSP card by CorelDraw V12
Postby Tech_Marco » Wed Jul 24, 2013 5:45 pm
Sorry, the above cut out is designed for SOLO with TB6560 driver card only. It is not for the DSP.
For the DSP (AWC608), please download the file below LaserCad file instead.
DSP SOLO USB CUTTING 1.pwj5
(208.93 KiB) Downloaded 377 times
DSP SOLO PANEL CUTTING 2.pwj5
(403.78 KiB) Downloaded 325 times
DSP SOLO PANEL CUTTING 3.pwj5
(63.14 KiB) Downloaded 310 times
Return to “K40 small laser”
