600x400 aluminum frames case part list and assembly guide
Postby Tech_Marco » Fri Mar 07, 2014 12:19 pm
Part list and assembly instruction for the 600x400 aluminum case. It apply to 900x600 as well except for the dimension (part list)
Aluminum Farme 640 Setup Diagram 20140312.pdf
(201.63 KiB) Downloaded 688 times
#640 Draft Dim 20131226 2.pdf
(531.32 KiB) Downloaded 361 times
#640 case solid a1.jpg (131.46 KiB) Viewed 5162 times
Re: 600x400 aluminum frames case part list and assembly guid
Postby Tech_Marco » Wed Oct 08, 2014 4:40 pm
Update: where is "T" & "L" bar installed to?
Return to “XY gantry and frame”
