Hello,
I had to update to a new computer with Win 10. I also upgraded from CorelDraw X3 to the 2019 version because X3 doesn't work on Win 10.
I downloaded the LO RDWorks v8.01.33. Loading the macro that exports your objects to RDWorks will not work. First off, there is no CD v2019 to choose. I tried many of the other options and that did not work. Any thoughts on how to get this working?
If I can't get this working, what is the best method of exporting a file that is engraved and cut to RDWorks?
Thanks in advance.
CorelDraw 2019 and RDCam Macro problem
Re: CorelDraw 2019 and RDCam Macro problem
Currently R5 or R6 doesn't come up plugin for Coreldraw 2019 . The easy way to get work done is to export drawing to DXF or AI (older version). I will make a request to Ruida to get the update asap
I fixed the plugin issue with patch files for RDworksV8. I've never used RDcam, but it's possible it would work similarly.
Basically all you need to do is replace folders and files in your CorelDraw 2019 installation directory to patch the plug in for RDWorksV8.
It generally works without any issues to speak of, but sometimes there are few other steps to get it functioning I can help you with Via email or my facebook page "https://www.facebook.com/groups/DIYLaser/"
Email and all other instructions are in the included "README Instructions" text file I've included with the zip folder if interested.
Download here>
https://drive.google.com/file/d/14uGf9l ... sp=sharing
Download here>
