I've just got JLD404 and the 75mV (500A) Shunt, but I could not find clear instruction where connect shunt to the meter.
This viewtopic.php?f=14&t=1057 shows a topic giving a basic picture, but not on the meter side.
JLD404 meter has #9 (75mV) and #10 (COM), is that where shunt connects?
Can you please clarify it?
Thank you,
-Y.
JLD 404 with shunt
Re: JLD 404 with shunt
You need to connect the shunt across on terminals #9 #10
Thank you,
Also will it measuring Volts or I need to hookup separately for it?
Not sure what you mean. Which JLD404 did you get? Power meter or AH meter?
Manual
Power meter:
viewforum.php?f=41
AH meter:
viewtopic.php?f=14&t=1074
Manual
Power meter:
viewforum.php?f=41
AH meter:
AH meter.
Any update? Working now?
i have't hooked up meter yet, just mounted shunt.
Also, question about shunt: Should I mount it on some sort of dialectic platform or is it sturdy enough to mount it on its own bolts between lugs?
