Array replication settings
Hydrops
Postby Hydrops » Fri May 18, 2018 8:09 am
Hi,
I'm doing a job using the array replication from lasersoft software but I notice that although it is indeed doing the array it is doing one by one, meaning it engraves one piece, then cuts it and moves to the next one.
How can I make it engrave all the parts in one turn and next cut them altogether ?
I have thousand of parts to engrave and cut and this way it'll take much longer.
Thank you
Hydrops
Re: Array replication settings
Postby Hydrops » Fri May 18, 2018 9:33 am
So I found out a way to do it
It might help so the way I did it was to do the array copy before transferring to bitmap, is this the correct way to do it ?
Return to “DSP T9”
