I have purchased the Lightobject k40 X7 upgrade. I need help with wiring on the Laser power supply to the controller. my laser power supply has these connections from left to right
L- FG AC AC G P L G IN 5V 24V G 5V L
Can someone help me on this I am using a separate 24v power supply and I cant figure out where the TTL and PWM from the controller plugs in to the Laser power supply.
LO X7 upgrade for K40 with MYJG40W laser power supply wiring diagram
Re: LO X7 upgrade for K40 with MYJG40W laser power supply wiring diagram
Here is the manual for connection: viewtopic.php?f=93&t=2484
You don't need to use the 5V or 24V DC power supply from our laser power supply if you have a separated DC24v dc source (better this way)
What you need to make it work is have these four pins connect: "L Wp Gn In" where L is TTL low signal, Wp= water protect, Gn= Ground, In=Input
Wp must be grounded in order to enable the laser power supply. Usually, you connect it to a water protection sensor.
Have fun on your laser!
LightObject
LightObject
Users browsing this forum: No registered users and 143 guests
