Decelerate after engrave
I'm wondering if anyone has seen this. I have high speed engrave passes followed by low speed cutting. I'm noticing that it takes a few cm to slow down after that transition. So the cut doesn't burn thru because its decelerating from 300 mm per sec. Running Raycam on a new X7 controller. Is there a setting to force the controller to complete the previous cut?
Re: Decelerate after engrave
What are you trying to cut with 300mm/s??
I can’t image anyone would do cutting for over 150mm/s of which we do outline of an object instead of cut through. You can’t break the natural of physics by not allowing stopping without acceleration oand/or deceleration. You may, however, adding delay (extend) the firing. Let me check the feature when I got back to my shop
So its an X_swing cut on a bmp file at 300. then I'm trying to cut the photo out at 7. I noticed it again when engraving text. I guess I could put the engrave pass last but my preference is to always do engrave cuts then cut thru in case the material moves when you cut thru.
I also had issues with the Y axis stepper which I fixed, so I'll post back if it goes away. So if this isn't something others have seen it probably the machine.
It was the machine. works fine now. sorry for bringing it up
Users browsing this forum: No registered users and 93 guests
