X7 DSP Origin Button - How does it work?
cryoteck
Post by cryoteck »
Hi, just finished upgrading my 60W laser with the X7 DSP :)
Now I can Jog the Steppers fine (X-Y) and even start the default program by pressing start.
My Question is about the ORIGIN button on the keypad...
Example if I Jog the steppers around the center, and then press Start the head goes back to the Top-Left (where the limit switches are) and starts the program.
Now if I Jog again to the center press the ORIGIN button and press Start again, the head still goes back to Top-Left and start the program from there?
My guess was that by pressing the ORIGIN button it would set the starting point of the program? Am I wrong or am I missing something?
Thank you for any help,
Yvan
tansh
Re: X7 DSP Origin Button - How does it work?
Post by tansh »
Press "Menu" button on the keypad, select "Common Parameters Settings" then select "Work Mode". Make sure that "Go origin After Reset" = Enable, and "Origin Mode" = Key Origin.
Users browsing this forum: No registered users and 23 guests
