Corel Draw X8 and Macro Install issue
When I try to install macro for Corel x8 32bit it tells me it can not find Corel. Where do I need to start. Windows 10 with Corel X8. Worked great when I had 12 and X4 but switched to Win 10 and X8 but now I can not get it to work again. Lasercad works no issue but really like using Corel.
Re: Corel Draw X8 and Macro Install issue
Just had to do it manually. Self solved.
How did you do it manually? I'm installing Corel 2017 (X19) and the install can't find Corel.
Thank you,
Jonathan
Thank you,
Jonathan
Same issue here. It would be really helpful if someone posted a manual install option or if RayCam would be updated to support the current version of CorelDraw.appareljunction wrote:How did you do it manually? I'm installing Corel 2017 (X19) and the install can't find Corel.
Thank you,
Jonathan
Having the same issue.
Could someone please give a description how to get this resolved.
I have tried everything I can think of.
If I point it to the Corel folder, it just tells me it is the wrong path ??
Any help would be greatly appreciated..
Received a new RayCam and ready to post. But, there is another version coming out and that put me on hold for a moment
Should be ready to download sometimes today
Actually the V18 did fix the VBA plugin error. Did you guys try it?
Note that there is no support for CorelDraw any version above X8 in the mean time
Anyway, here is the RayCam for X7 v19
viewtopic.php?f=55&t=3619&p=17443#p17443
I have Raycam V19 and CorelDraw X8 and same problem. Has anyone figured it out?
To be specific I have CorelDRAW Home & Student Suite X8
Can anyone help with what folder I need to point the installer to in order to install it manually? The RayCam installer can't find Coreldraw with the auto installer.
It won’t work with home and student suite. The Corel Draw macro requires Visual Basic and home and student suite doesn’t have that.
For the others - Even if you could install it into the Corel directory manually you won’t have the macro installed.
I assume that RDCam is very similar to LaserCad, so you can install the macro manually if you can get hold of the files and install the program elsewhere then copy it over to the Corel programs directory.
However this is not easy and you have to be able to know where to install the macro and how to add it into Corel.
You’ll also then get into the issue of having two sets of RDCam on your computer. One in the usual place and one in the Corel directory. Then you’ll have the issue of the config files for the two different programs being in two different places. The Corel installation installs them in a weird directory deep in windows.
In short. It’s difficult and not worth it.
Users browsing this forum: No registered users and 78 guests
