Out of the blue my laser is printing in reverse. Mirrored you might say. This happened once in the past and I was somehow able to get it to print correctly again but haven't been able to this time. I can't remember what I changed. What setting do I need to change? As of now I am mirroring the output before sending to the X7 DSP from CorelDraw so it prints correctly.
Bill
Laser Printing in reverse.
Re: Laser Printing in reverse.
Check page zero, machine zero, and position relative. Make sure it match your physical home location. That should take care the issue
Thanks Marco for getting back so quickly. I check all the settings and they are all "Left Up" as should be. When I laser a arrow pointing to the right it will laser a arrow pointing to the left. This is pretty frustrating..
First of all, let me move your topics to the other section because this section is for 'sale and wanted'
What version of LaserCad are you using? Get the newer one may solve the problem. The latest LaserCad is v7.86.1
Thanks Marco! Didn't realize I put it int he for sale section. My current version is v7.78.10. I will get the new version and see what happens.
Bill
Bill
