Hi,
I was able to get one of these for a really good price directly from Ten-High:
http://www.amazon.com/TEN-HIGH-Upgraded ... 01D2PPA2C/
http://www.ten-high.com/productsinfo.aspx?productid=502
I'm just linking to the Amazon page because it shows a photo of the 60W unit.
Does anyone here have experience with this machine? I'm wondering what I should expect once it arrives in terms of the controller and software. I know it doesn't use the moshidraw cr@p but that's about it.
Would the controller kits sold here for the K40 machines be applicable to this machine?
TH-CO2-430-60W (60W Generic Chinese Laser Cutter)
Re: TH-CO2-430-60W (60W Generic Chinese Laser Cutter)
I've been trying to do my research and I can't figure out if I'll need this:
http://www.lightobject.com/X7-DSP-Contr ... -P940.aspx
Or this kit:
http://www.lightobject.com/X7-DSP-upgra ... -P942.aspx
Based on the photos of the machine I'll be receiving, there are a lot of parts in the kit that I wouldn't need because the machine already has them. The stepper drivers are mainly what I'm concerned about needing. The machine has a digital readout. So I'm assuming it already has 24v and 5v power supplies.
Or this kit:
I went ahead and purchased the kit. Worst case is I have a few spare parts.
Hello
First of all, I doubt it that it is a 60W machine. Most likely it is a 40W machine due to the physical size limitation.
You may get the DSP card only if you think that the machine comes with all necessary parts
We will launch small laser machine "PR530" on July. It is high speed machine with 500x300 work area. It comes with a 850mm 40W laser tube and can be expand to a 1M 45W(50W peak). We are selling it for $3,495 and it comes with Element E5 DSP controller. Also, it comes with power Z table
Users browsing this forum: No registered users and 71 guests
