What are the IO specs on the 708C controller, I cant seem to find a real manual for it. The inputs have connections for +24v ,inputs, and ground. So can I pull the input low with ground or bring it high with 24v?
Are the output pins 24v out?
IO Specs on X7
Re: IO Specs on X7
I really need this info to get this thing installed. I tried a direct email and no response there, either.
Re: IO Specs on X7
Most inputs a a kind of TTL inputs, although the level is +24V/0V rather than the 5V of normal TTL
Outputs are most likely "OpenCollector"-types. A transitor in this outputs pulls the level to ground. You may drive +24V but the current is very low and if you plan to drive a solenoid (like a relais) take care to place a diode to damp the induction-voltage from this solenoids else you will blow the output!
Users browsing this forum: No registered users and 99 guests
