Tech_Marco wrote:There is nothing wrong with the DSP and both limit switches worked as the way it should.
Somehow you set the Start speed to "0.035mm/s" when it should be 10 or 20mm/s on the "User parameter" setup menu.
Card already shipped out 3 days ago and you should receive it today
Received, installed, and confirmed it works as it should. I can move the cutting head via control panel or software buttons as needed. Excellent!
Got the UM value set so it does make for a nice 100x100 box reliably.
It still leaves gaps at the start and end of a line. Tried a square- each side is short with a gap at the beginning and end of a side. A circle has a gap at the beginning and end of the line. I recall you mentioning there was a possible setting for this. I will go back and reread this entire thread and follow your instructions exactly.
I'm feeling more confident now than I ever have before for success. The hardware works! An excellent kit indeed.
