How do you change the homing offsets? I want me machine to home itself, and then move to the corner of the bed which is at 0, 30. I have a jig setup there so I don't want to work in anything bu "soft origin" work mode. How do you go around this? Right now I'm having to just remember to move all my cuts down below 30mm in raycam.
Change zero coords? Homing offsets?
Re: Change zero coords? Homing offsets?
I'm having exactly the same issue. Did get it solved? I'm using LaserCad but I'm sure that doesn't matter.
Dean
Dean
Move the head to the exact position you want using the software. Then push the origin button on the LCD screen which resets the home position.
Or mechanicaly position the home-sensor to the appropriate coordinates: move it 30mm to the left/right/forward/back.
Or mechanically extend the sensor-trigger by 30mm.
Or set your origin right (like ChrisBorg said)
BTW i always use a origin somewhere where i can position my material easily..
Users browsing this forum: No registered users and 77 guests
