Hello,
I am wondering if it is possible to use upgrade my LC1390's controller to the DPS X7 that is available here. Also, how much work it would require.
Thanks in advance for your response!
E
Upgrade WKLaser LC1390 DPS to X7
Re: Upgrade WKLaser LC1390 DPS to X7
Sure it's possible... But you have to find out what controller(type, brand,,) is in it now and what all wires do..
If you know that, it's a matter of a few hours to replace it and program the controller to your machine-specific settings..
(that is, if you're quite good in building machines and understand how a laser works... )
Techgraphix,
Below is the link of the Laser Cutter I purchased.
http://www.wklaser.com/index.php?m=cont ... l=2&id=500
It runs MCP6515B I am not sure if this helps...
Ok, i found out the following from the Leetro MPC6515 manual and the LO-X7 (= ~ AWC708C-Lite)
One extra thing to get the laser to work:
Or you connect the waterprotect-switch to the controller (connector 6 - Pin 2) and make a shortcircuit between the WP and GND of the laser-power-supply ..
Or you connect the waterprotect-switch to the WP and GND of the laser-power-supply and make a shortcircuit PROTECT to GND of the controller (connector 6 - Pin 2 to 6 - Pin 5 )
In both cases you also have to shortcircuit the PROTECT to GND of the Laser2 connector ( connector 5 - Pin 2 to 5 - Pin 5)
I prefer to connect the WaterProtectSwitch to the controller..
See if you can get it to work with the next table:
MPC6515......................................LO-X7........
X1 - Pin 1........+24V........................PWR - Pin 1........24V
X1 - Pin 2........24V GND...................PWR - Pin 2........GND
X2 - Pin 1........Footswitch................11 - Pin 2........IN1
X2 - Pin 2........Uncapping Protection...11 - Pin 3........IN2
X2 - Pin 3........Reserve
X2 - Pin 4........GND........................11 - Pin 6........GND
X2 - Pin 5........5V/24V
X3 - Pin 1........Z-axis Fwd Limit...........9 - Pin 3........ELZ+
X3 - Pin 2........Z-axis Rev Limit............9 - Pin 5........ELZ-
X3 - Pin 3........Z-axis Origin
X3 - Pin 4........GND..........................9 - Pin 6........GND
X3 - Pin 5........5V/24V......................9 - Pin 1........DC24V
X4 - Pin 1........Y-axis Fwd Limit...........8 - Pin 2........ELY+
X4 - Pin 2........Y-axis Rev Limit............8 - Pin 4........ELY+
X4 - Pin 3........Y-axis Origin
X4 - Pin 4........GND..........................8 - Pin 6........GND
X4 - Pin 5........5V/24V......................8 - Pin 1........DC24V
X5 - Pin 1........X-axis Fwd Limit...........8 - Pin 3........ELX+
X5 - Pin 2........X-axis Rev Limit............8 - Pin 5........ELX-
X5 - Pin 3........X-axis Origin
X5 - Pin 4........GND...........................8 - Pin 6........GND
X5 - Pin 5........5V/24V........................8 - Pin 1........DC24V
Y1 - Pin 1........Blow-off......................1 - Pin 2........Out 1
Y1 - Pin 2........Processing Finished
Y1 - Pin 3........USB Flasdisk indication
Y1 - Pin 4........Reserve
Y1 - Pin 5........GND............................1 - Pin 4........GND
Y1 - Pin 6........5V/24V........................1 - Pin 1........DC24V
Y2 - Pin 1........Laser Power GND.............6 - Pin 5........GND
Y2 - Pin 2........Analog Output................6 - Pin 3........PWM
Y2 - Pin 3........Laser Power
Y2 - Pin 4........Laser On/Off..................6 - Pin 4........TTL
Y3 - Pin 1........Z-axis Pulse...................7Z - Pin 2........PUL
Y3 - Pin 2........Z-axis Direction..............7Z - Pin 3........DIR
Y3 - Pin 3........5V GND
Y3 - Pin 4........+5V.............................7Z - Pin 1........DC5V
Y4 - Pin 1........Y-axis Pulse...................7Y - Pin 2........PUL
Y4 - Pin 2........Y-axis Direction..............7Y - Pin 3........DIR
Y4 - Pin 3........5V GND
Y4 - Pin 4........+5V.............................7Y - Pin 1........DC5V
Y5 - Pin 1........X-axis Pulse...................7X - Pin 2........PUL
Y5 - Pin 2........X-axis Direction..............7X - Pin 3........DIR
Y5 - Pin 3........5V GND
Y5 - Pin 4........+5V.............................7X - Pin 1........DC5V
Succes
Succes
Amazing info! you are a wizard and a gentleman!
I have ordered the X7 upgrade and should be getting it next Tuesday. I will definitely keep you posted how it goes
Users browsing this forum: No registered users and 95 guests
