Lasersoft vs Lasercad
Posted: Tue Aug 22, 2017 8:59 am
by BanksCNC
Hello.. I've noticed in the FAQ /Readme that Lasercad is mentioned as the control software and on the instructions on how to do things. My T9 DSP uses Lasersoft witch from my understanding is the new software Marco has had created. How much different is Lasersoft from Lasercad? will Lasersoft/Lasercad instructions and howto's be basically the same or are they completely different beasts.
Brandon
Re: Lasersoft vs Lasercad
Posted: Tue Aug 22, 2017 9:39 am
Those software shares a lot of common in terms on functions. Things that differentiated cards are the name of the software and the labeling. I have posted all software and you can download and install it for testing. You should find that they are 90% are common
Posted: Tue Aug 22, 2017 10:33 am
by BanksCNC
Cool...I like lasersoft so far I was just curious if they matched up. Is it possible to use Lasercad or other laser software with the T9?
Posted: Tue Aug 22, 2017 10:57 am
No they are not compatible
