coreldraw & ramcam to import
Posted: Sat Jan 14, 2017 7:39 pm
by tehamatees
I am a Coreldraw user (x6) and I just downloaded RAYCAM. I am trying to import CORELDRAW files into Raycam and Raycam wont recognize them. What do I need to do to make this work?. I've used the computers and machines at L.O. Hq and there is a shortcut tab (top tool menus line) in their computer that jumps from Coreldraw to Raycam. What do I need to do to succeed?
Re: coreldraw & ramcam to import
Posted: Sun Jan 15, 2017 10:30 am
Run the RayCam installation program and select CorelDraw add on module. Select the version and point to the correct path and that should take care it for you
Posted: Thu Feb 23, 2017 5:22 pm
by Winstonc
I am trying to install the RayCAM plugin for CorelDraw X8 and after choosing the right version and directory it keeps comming back with directory not found. I have tried every combination I can think of with the same results.
Any suggestions?
David
Posted: Fri Feb 24, 2017 8:05 am
So far both RayCam or LaserCad supports CorelDraw up to version 7.0 only
Will discuss with the programmer soon about the issue
Posted: Fri Feb 24, 2017 8:08 am
by Winstonc
Ok, thanks Marco
Posted: Fri Feb 24, 2017 10:45 pm
by Winstonc
Does the plugin only work with the full version of the Coreldraw X7 or will it work with the Home and Student version? Just wanted to check before I buy.
David
Posted: Sat Feb 25, 2017 9:21 am
by Winstonc
I think I have answered my own question and the answer is it requires the full version to get macro support.
David
