Print driver question
Posted: Sun Jul 24, 2016 5:04 pm
Hi folks:
I discussed with the programmer 'Li' about the print driver. I think he may hit the curve by finding driver sources and he was wondering if he could pay for some sources code for the driver? I'm not a programmer so I know nothing about it. Anyone with programming background want to feed some output here?
If he doesn't do the Print driver, then he need to create 'add-on' VB module for CorelDraw, Illustrator, AutoCAD,... InkEscape. But, the problem is that application developer from Illustrator or AutoCAD ares keep changing and the source is not opened, he has hard time to catch up. That's why LaserCad sometimes can't import DXF files or AI files properly. We got to make sure that the LaserCad can handle some version if not all version. Your input is greatly appreciated!
