20W Fiber Optics metal engraving machine cutting capability
Posted: Wed Sep 03, 2014 12:08 pm
This is a testing result for a 20W fiber optics machine
Thickness (mm): Number of pass:
0.1 5
0.2 15
0.3 35
0.4 80
0.5 120
0.75 800
It is just a referrence what a 20W engraving machine can do on cutting metal (iron plate)
Re: 20W Fiber Optics metal engraving machine cutting capabil
Posted: Sun Sep 07, 2014 2:15 am
by NickWL
How come this 20 watt machine an cut through spring steel when my 35 watt K40 can barely cut through 3mm plywood?
What am I not understanding?
Posted: Mon Oct 13, 2014 11:07 am
The wave spectrum of this machine 1064nm while a CO2 is 10600nm. It is a different kind of laser. The 1064nm got no reaction when it touch your skin but the CO2 will burn your skin badly
Posted: Thu Nov 06, 2014 7:17 pm
Update: received the 20W fiber optics machine and ran a few test
Note: I was doing 3~5 pass per customer request. It is because he need at least 0.1mm etched deep so that the serial number won't be wrapped out easy. Plus, it was doing both vector cutting (outline) and engraving so it take a bit longer. If I only do one pass without outline, it take may be 1 or 2 seconds only. Super fast compare to CO2 laser machine using stepping motors or servo.
Posted: Thu Nov 06, 2014 8:56 pm
by swamidog
that is lovely!
i've done a fair amount of marking on anodized aluminum with the co2 system i bought from you, but nothing beats galvos and an f-theta lens for speed.
Posted: Thu Nov 13, 2014 4:26 pm
More testing has done and a few video will be posted once uploaded to the Youtube
Posted: Thu Nov 13, 2014 4:28 pm
More...
Posted: Sat Nov 15, 2014 2:29 am
by NickWL
What does one of these cost Marco?
Posted: Sat Nov 15, 2014 7:21 am
by NickWL
M A R C O !!!!
What does one of these cost?
Nick
Posted: Mon Dec 22, 2014 11:17 am
From $11,500 to $23,500 (10W to 30W)
It is fast and it is powerful!
Posted: Mon Dec 22, 2014 11:24 am
More samples:
Posted: Tue Dec 23, 2014 2:37 am
by NickWL
Which part makes it so expensive?
Posted: Tue Dec 23, 2014 12:57 pm
Galvo - high speed mirror system
Laser module - either made in Germany or Chinese
Other than that, no other parts inside the machine surprise you
I'm getting a quote for the 100W, 300W, and 500W laser module. I may come up my metal cutting machine that is capable to cut up to 5mm thickness stainless steel in one pass!
Posted: Tue Dec 23, 2014 3:36 pm
by NickWL
I remember building high-speed mirrors in the late 1960s for use in 'light machines' in clubs and discos. We made them far more precise than necessary - but the were far better than today's feeble efforts (and far more expensive!)
Nick
