Hole Cutting Template for LO-X7 Controller
DonL
Postby DonL » Sat Dec 19, 2015 1:31 am
When you go to cut the hole for the controller, note that the hole is off-center so to make things easy, I cut the attached laser file out of a thin material and used it as a templyer, place the template where you want the controller and trace the inner cutout with a pencil or marker, cut the hole along the lines and the controller will fit in the exact spot you wanted it.
LOX7 Template.pwj5
(104.56 KiB) Downloaded 151 times
Return to “Artwork from DIY'er (share your art design)”
