Some stuff I've made :D
Things
Postby Things » Sun Jul 14, 2013 2:12 am
Usually as a result of boredom :D
Dan
wctx1977
Re: Some stuff I've made :D
Postby wctx1977 » Sun Jul 14, 2013 10:35 am
Very nice!!! I wish I had time to go back to mine and fix it :cry:
DonL
Postby DonL » Sat Dec 19, 2015 1:52 am
I came across a product called BONDIC
It is a liquid plastic that you apply with the needle applicator and then the other end of the applicator is a UV LED, shine the UV light on the liquid and it cures in 3 seconds, Just like the dentist uses to fill cavities. You can make threaded parts, repar and use it as a glue...
You guys may find it very hady as there is no need to wait for hours while conventional cement cures.
I took 2 aluminium laser heads and bonded them together using this product and it is rock solid and I was able to test the laser head on the machine at full speed in just seconds...
If you need more details, PM Me. :geek:
Cheers!
mrsunnylam
Postby mrsunnylam » Thu Nov 08, 2018 10:10 pm
I have used something similar. It was UV resin. In harden in seconds
Return to “Artwork from DIY'er (share your art design)”
