LO-X7 XY Limit Switches Inop
Posted: Mon Jun 25, 2018 7:12 am
I’ve upgraded my K40 over the last week with the LO-X7 DSP, LO-60W PSU, and the LO Z-axis table … potentially a very nice setup. Finished wiring up everything over the weekend and all is work perfect with the exception of the XY limit switches.
I have hard mounted (i.e. with screws) mechanical switches, currently wired for Normally Opened … and have verified continuity (repeatedly) and am convinced that the switches are good. The switches are connect to X-/Y-/GND on the controller.
The only software setting I have changed, at least for this, is in the Manufacturer Parameters, to enable Hardware Limits for both the X and Y. I’ve actually tried it both enabled and disabled with no change.
One strange thing while I was trying various things to get it working; I hooked up another limit switch on the X+/GND (it was one I had lying around wired up for Normally Closed) and with it in place the X-/Y- switches started responding. OK, since this switch was N.C., I took it out and just replaced it with a jumper wire to see if I could reproduce it … nope, back to not working. In fact, even putting the extra switch back in (which really shouldn’t be required) I could never reproduce my one time success.
I’m sure I’m missing something simple here … limit switches are pretty basic and I’m not a complete newbie to X/Y/Z systems (not an expert either), so I would welcome any suggestions. I’m not to the point of calling into question the DSP controller (yet), but I’m running out of ideas.
Thanks in advance for any help,
Frank
Frank
