LaserCAD plugin not showing CoreDraw X7 64bit
Posted: Mon Nov 14, 2016 4:53 pm
Ok I have LAserCAD 7.86.1 installed and CoreDraw X7 fully updated. I cannot get the plugin to connect. I even pointed the LaserCAD Software to the appropriate default CoreDraw X7 directory. It appears to install fine ...says all is good. However, when I open CoreDraw X7 and check for the plugin, it is not listed. Nor is it on the tool bar (nor when I right click on tool bar, LaserCAD does not show). Any ideas?
System info below
System
Platform: Windows 10 Pro
Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
Number of Processors: 8
Math Coprocessor: No
Total physical memory: 16322 MB
Available physical memory: 11947 MB
Total virtual memory: 18754 MB
Available virtual memory: 13584 MB
Available space on drive C: 1767464 MB
Available space on drive D: 88010 MB
Available space on drive F: 31102 MB
Available space on drive G: 373787 MB
Available space on drive I: 92255 MB
Available space on drive J: 470782 MB
Available space on drive K: 616677 MB
Available space on drive O: 108100 MB
Available space on drive P: 5009 MB
Windows Directory: C:\windows
Box name: CorelDraw_17
Application directory: C:\Program Files\Corel\CorelDRAW Graphics Suite X7\Programs64
System info below
System
