GFCI outlet with k40 laser?
Toasty
Postby Toasty » Fri Feb 15, 2013 5:43 am
Because these machines use water around electronics I would like to plug my k40 into a GFCI outlet.
Would there be an issue with the GFCI shutting off all the time because of it detecting leakage from the high voltage cable?
Anyone here running a k40 with a GFCI?
Re: GFCI outlet with k40 laser?
Postby waltfl » Fri Feb 15, 2013 12:51 pm
Hi
yes I got ot on a gfci and no problem
Toasty wrote:Because these machines use water around electronics I would like to plug my k40 into a GFCI outlet.
