I need the Dipsswitch settings for the Z table!
6 DIPs
Zlm3020
Z Table Dip Switch Settings
Re: Z Table Dip Switch Settings
Here is the setting from SW1 to SW6: On Off Off Off Off On.
If you think the motor is moving too fast or too big step, change the resolution to 3200 by changing SW4-SW6 to On On Off.
Hope that help.
J
Hope that help.
J
Dip settings are correct!
Need to verify wires?
Red, brown, yellow, orange go to?
My table beeps when I push up or down but will not move?
Thoughts?
Thoughts?
You may test the motor movement before putting it into the Z table. That way you can tell if connection is correct or not. Also, check the motor wire pair. Sometime the motor wire terminal mapping sequences is different . Example:
A+A-, B+B- or. A+ B+ ,A- B-
Users browsing this forum: No registered users and 76 guests
