IR Led in series
rlowery98
IR Led in series
Postby rlowery98 » Wed May 25, 2011 3:00 pm
i am building a IR project box with 10 ir leds in it i have them wired in series not parallel
i am using the 10mm Triple chips 200mW IR LED (a pack of 10)
how big of a battery would i need and how big of a resistor will i need to run the 10 led bulbs in my project box?
i have a 9volt battery connected to it now and each led has one volt going to it but it does not lite up
any help would be appreciated
thanks
robert
Re: IR Led in series
Postby Tech_Marco » Sat May 28, 2011 3:11 pm
The IR LED has 1.6V forwarded voltage so if you put 10 in series, it's potential drop would be 16V. There is no way for a 9V battery can light it up.
In your case, you may want to do 5 in series and add a current limited ressitor to avod over current.
The resistor could be 16~18 ohm. 1/4 watt
Then you put two set of LED/R in parallel and end up 10 LED in total. Current would be running about 200mA
For a 9V battery, it may ligh it up for 3hrs
Return to “LED”
