LEDs and Drivers
bwells
LEDs and Drivers
Postby bwells » Sat May 22, 2010 3:28 pm
I want to combine 8 of these LEDs into a series string.
http://www.lightobject.com/10x-10mm-3-C ... e-P91.aspx
Do you sell an LED driver I can use to maintain a constant current for these 8 LEDS? I plan to power the 8 LEDs with a 12 volt battery and had planned to use the appropriate resistors to drop the voltage to the rated voltage.
Re: LEDs and Drivers
Postby Tech_Marco » Sun May 23, 2010 10:35 pm
Put all LED in parallel and use a 3Watt LED driver should be good enough to drive it well
bwells
Postby bwells » Mon May 24, 2010 4:30 am
Thank you for the suggestion.
Can you tell me how that will work out? I am just learning about building these LED circuits.
  • The forward voltage of each LED is 1.4V. In parallel, the voltage will still be 1.4v. But I plan to use a 12v battery to drive my circuit. And the driver is rated 5-8 volts. I cannot put 12v to this driver, right? What keeps the LEDs from getting more than 1.4V they are rated for?
  • The IF for the driver is 750mA and the IF for the LED is 140mA. 8 LEDs in parallel would mean the IF is 1120mA. That is well below the 750mA from the driver. So will my LEDs be bright enough? Don't I want to get closer to 1120mA?
  • Finally, I see the driver is rated at 3watts. Can you tell me how the 3watts fits into the equation?
Thanks for your help!
egbertdavis
Postby egbertdavis » Fri Feb 04, 2011 3:48 am
I'm interested in the follow up answer as well. Also, I am planning on using the 10mm LEDS as well, but would like to run 18 in three three rows of 6 or ideally 20 using 2 rows of 10. Can this be done with the driver? Maybe 2?
Thanks.
Return to “LED”
