I am looking for the tube (I believe it may be silicone) that the Chinese use to surround the wires going to the laser tube. http://www.lightobject.com/SPT-850mm-CO ... Id=1346675 This wire is one of them that I need a jacket to use on to protect from the 15-25k volts that goes over the silicone I put directly over the stud and wire.
Have something suitable for sale?
Laser Jacket
Re: Laser Jacket
It’s standard pvc tubing. Nothing special.
Re: Laser Jacket
By the way. From now on I recommend you get them to connect the wire at the factory and use a IP68 inline connector for your positive wire. It’s much safer. It need to be rated quite high. You can get 17 amps at 400v which is more than enough power rating for - for example - 0.25 amps at 2Kv.
Re: Laser Jacket
They have silicone tubing
https://www.lightobject.com/mobile/8X12 ... -P752.aspx
Users browsing this forum: No registered users and 66 guests
