Right inch gauge tube for Water Pump with 7mm output?
chrisrauh
Postby chrisrauh » Tue Jan 08, 2013 10:36 am
I am trying to find out what inch internal diameter fits the output of this pump (7mm OD):
High temperature(100'C) DC 6V 1L/Min (15GPH) mini Water Pump. FDA Food grade
http://www.lightobject.com/High-tempera ... -P510.aspx
Seems like 5/16" is too large and 1/4" is too small. There doesn't seem to be sizes in between those for PVC tubing in the US.
Would appreciate any pointers.
Christian
Re: Right inch gauge tube for Water Pump with 7mm output?
Postby Tech_Marco » Tue Jan 15, 2013 12:05 pm
Return to “Others”
