New LCD Panel for the DSP controller card 2012 (AWC-608)
Postby Tech_Marco » Tue Apr 03, 2012 2:44 pm
Check it out, the new LCD panel!
The reason for rolling out the new layout because some folks got confused with the old controller that designed by "Tech Wang" in hardware, software by "Li". And the sneaky "Thunder-man" who claimed he created and manufactured the DSP controller which of course not true (sorry for that little bird). To avoid the confuse, Li and new teammate (hardware engineer and marketing) decided to change the layout of the panel by drawing a 'clean' line between these two cards.
FYI, the old card doesn't support real-time X-Y coordination, fast pan, job simulation, PPI, Air-pump, and network file transfer, and more. Only the new card does!
After 6 months great effort, the new DSP (AWC-608) is more solid and promising. Thank you for the patience and support by all folks who purchased. I'll do as much as I can to support it
Marco K. Wong
International Distributor
Return to “News”
