New Cooler Radiator Copper tubing sealed
Mcaughey
Postby Mcaughey » Tue Sep 05, 2017 5:13 pm
I picked up the 12INCH (300MM) WATER EVAPORATOR/ COOLER RADIATORS FOR CO2 LASER COOLING
http://www.lightobject.com/12inch-300mm ... -P713.aspx
The copper tubes are sealed on the end. I'm assuming, but want to verify first. I am supposed to cut these and one is the input (top) and one is the output (bottom).
Thank you.
Re: New Cooler Radiator Copper tubing sealed
Postby Tech_Marco » Tue Sep 05, 2017 5:21 pm
Yes, you need to cut it out. The radiator is filled with nitrogen to ensure no leak.
Be expecting a loud 'pop' sound when cutting it. Please wear a protection goggle to protect eyes
