Hi, I have a recently purchased and got online an older Lightobject 150 watt CO2 laser cutter. I have a client who needs material cut at a 45° angle.
The solutions I've seen online are either to build a jig or have a modified laser head that cuts at an angle. Due to the size of each work piece, I can't reliably use a jig for the cut.
Does anyone have a source for a modified laser head that can cut at an angle? Either for purchase or fabrication? Or other suggestions?
Josh
45° angle cutting head for Lightobject cutter?
Re: 45° angle cutting head for Lightobject cutter?
It's not quite possible unless you 3D print an angle adapter. But it is almost "mission impossible" unless you are a good CNC and know Solidwork or Fusion360. Plus, even though you could make the adapter, it works for one 'one' side only because the angle is fixed. So, I will suggest not to go this route.
The reason I ask is there is a company in Indonesia called IDI Laser Services that has a laser head that does these kinds of cuts.
I've got the jig half designed though, so that's the current/only route available right now.
Anyway, a head like this might be an add-on you guys can offer at some point, as it solves certain problems for certain jobs.
Best,
Josh
Best,
Josh
I don't see any good use in common because the angle is fixed but not 'dynamic'. It only works for very specific needs but will not be common
Users browsing this forum: No registered users and 137 guests
