NEMA 23 3 PHASE 573S15 5.2A 212IN-OZ STEPPER MOTOR
robstach2
Post by robstach2 »
Okay - maybe I was a bit ambitious for a first build but I'm sure I can do it.... I think.
It would certainly help if there wasn't so much conflicting information though!
Here's my latest dilemma. MY Y motor only has 3 wires as stated below but when pulling up the product page it lists it as having 6 wires.... ;)
Additionally, as you can see below, the X motor claims to have 3 wires but mine has 6...? This matches the product page.
So, setting the driver to 5.8 A for a test, I get a very shaky start until the DSP boots. According to the diagram I was sent, there is a jump between PUL+ and DIR+ ... anyone know if this is correct?
Specification:
X motor:
Brand: Lightobject 573S09 3-phase
Step angle: 1.2 degree
Torque: 128 oz-in
Current: 3.5 A
Resistance: 1.3 ohm
Inductance: 1.7 mH
Detent torque: 4 N.cm
No. Wire: 3
Weight: 0.75Kg (1.65 lb)
Y motor:
Brand: Lightobject 573S15 3-phase
Torque: 188oz-in
Current: 5.8A
Resistance: 0.7ohm
Inductance: 1.35mH
Detente torque: 6.8 N.cm
No. Wire: 3
Weight: 1.1Kg (2.4lb)
robstach2
Re: NEMA 23 3 PHASE 573S15 5.2A 212IN-OZ STEPPER MOTOR
Post by robstach2 »
Based on my response fro LO Support, I need to set the current to one step lower. That's fine.
Still, any thoughts on my motor acting crazy during boot? Humming, spinning, and sputtering.
robstach2
Post by robstach2 »
Just received some AWESOME support from Marco.
Turns out I have a bad driver and he's replacing it...
I knew I wasn't nuts!
Thanks Marco!!!!
Users browsing this forum: No registered users and 93 guests
