return to last origin point
Postby vindelsbek » Sun Nov 19, 2017 4:35 am
I have a problem, when I start my laser with the AWC 608 controller.
During start up, it runs to the limit switch and lights up green but it does not run back to the last origin point. It just keeps standing at the limit switch and buzz as hell
please help someone
Re: return to last origin point
Postby Techgraphix » Sun Nov 19, 2017 5:51 am
I guess you have a problem with the limitswitch or configuration. (ie the wrong direction or corner)
From the buzzing i conclude that it still powers the motors to move further to trigger the sensors?
BTW what kind of limitswitches you use? microswitches or proximitysensors ? and how are the placed in respect to the movingdirection?
And is this a fresh install or did it work fine before (without modifications)?
If it worked fine before, check the limit switches and motordrivers.
