Wiring 6 wire 3-phase stepper to 3 phase driver
Posted: Thu Apr 13, 2017 1:56 pm
by Winstonc
I have a NEMA 23 3 phase 573S15 5.2A 212in-oz Stepper motor http://www.lightobject.com/NEMA-23-3-ph ... -P888.aspx and a NEMA 23 3 phase 573S09 3.5A 127in-oz Stepper motor http://www.lightobject.com/-NEMA-23-3-p ... -P914.aspx that I need to wire to two 3MD560 Leadshine Compatible 3 Phase 8.4A 1-axis Stepping Motor Driver http://www.lightobject.com/3MD560-Leads ... -P836.aspx.
I know they connect to the U,V and W terminals on the drivers and I assume that as the steppers have wires that I connect pairs of them together to then run 3 wires to the drivers, but I am unsure as to what the color pairs are and also what color goes to which terminal on the drivers.
If I could get some guidance, I would be very graterful.
David
