Aluminum Frame for 600 x 400 kit
Winstonc
Postby Winstonc » Thu Mar 23, 2017 11:19 am
I have my kit on the way and have redrawn the constructed kit in Fusion 360 so I can use it as a basis for the rest of the build.
Based on the LO setup diagram, there seems to be a discrepancy in one of the dimensions as follows:
1. Assuming on the second horizontal level from the bottom that the distance between the 2 "d" lengths on the left hand side is equal to the dimension of the "l" lengths
2. Assuming on the second horizontal level from the bottom that the distance between the 2 "d" lengths on the right hand side is equal to the dimension of the "i" lengths
The length of part "e" should be the same as the length of part "f", however it is 5mm longer (805mm vs 800mm). Is this an error or have I made an incorrect assumption?
Thanks for the help.
David
