This is what I am looking at- Special Pro laser head mount for 30mm mirror & 25mm focus lens. LR Type
I need a mount that will accommodate both 1.5 and 2 inch FL lenses- are those nozzles available for this mount? Also where does the lens mount in the head- in the barrel (I assume) or the nozzle. If in the barrel can an additional barrel be purchased separately? Thanks Gene
PS I have a 100w Bodor desktop type laser and a 130w 1300x900 cabinet style laser, both would profit from better head mounts.
Laser head question- Special Pro laser head mount
Re: Laser head question- Special Pro laser head mount
No, this mount is designed for lens with f:63.5mm. The supplier may no longer making this laser head. It is hard to get a hold with him to get the status. So, I may stop selling this laser head soon
The lens mount is on the barrel, not on the tip if I'm not forgotten. I'll double check it later
