gp400z burn out?
Posted: Sun Jan 03, 2016 10:08 am
by the_dude
Was happily working yesterday when power went out to my GP400.
I unplugged and replugged the unit back in.
I could see the power flash to the led of the gp400 and stepper controllers for a fraction of a second but not stay on.
I took the cover off to check the fuse inside and that was not blown.
I then got the multimeter out and made sure I have 120v coming in and V1 and V2 are out putting 1.7v and 7v respectfully.
Any ideas? please help.
Re: gp400z burn out?
Posted: Mon Jan 04, 2016 2:49 pm
I don't think anyone know your machine at all by just posting the model number "GP400". Note that there are thousands of different model laser machine out there and the model means nothing. You need to be more specific on your problem and you need to provide more info about your machine before asking help from us. Can't just ask "It won't work, why"
It is better to post pictures of your machines.
Posted: Mon Jan 04, 2016 3:09 pm
by the_dude
Its the GPZA400U power controller that I bought from light object for a 600x900mm 100watt build.
Posted: Mon Jan 04, 2016 4:20 pm
Power controller? Did you mean the "Laser power supply"?
Shoot me a picture, please
Posted: Mon Jan 04, 2016 4:34 pm
by the_dude
Posted: Mon Jan 04, 2016 4:55 pm
by shanet94
That is the power supply for the dps. V1 should put out 24V and V2 should put out 36V what do you have this hooked up to power?
Posted: Mon Jan 04, 2016 5:00 pm
Did you set the AC power switch to "AC110V"?
By default, it is set to AC220V
Posted: Mon Jan 04, 2016 5:03 pm
by the_dude
Yes I understand it should be putting out 24/36v. It was working completely fine as was the whole system until it randomly stopped between jobs, so as said in first post I opened it up checked fuse and the outputs that are very low. Yes it is set to 110.
Posted: Mon Jan 04, 2016 5:09 pm
Unplug wires that connected to the output and test the open voltage appears on the output terminals. You may have shorted circuit somewhere or it may be a faulty DC power supply (very low chance)
Posted: Tue Jan 05, 2016 1:45 pm
by the_dude
Thank you Marco!
From the looks of things I would appear there is a short in the system despite nothing changing.
Going to rewire and let you know.
Thanks again
Posted: Tue Jan 05, 2016 6:39 pm
by the_dude
I'm pulling things apart to find the short and I can't find a wiring diagram anywhere for a awc608 to jp 100, to GPZA400U.
Could you link me please?
Posted: Tue Jan 05, 2016 8:23 pm
There is no connection diagram specificly for the power supply and the DSP. We provide generic connection diagram only. DC36v for the motor drivers and 24v for the DSP card.
Posted: Tue Jan 05, 2016 9:45 pm
by the_dude
what about for the jp100 laser power supply?
Posted: Tue Jan 05, 2016 10:50 pm
Didn't you receive a complete connection diagram from us?
Most PWM laser power supply are having almost identical connection. You can find the connection here by searching on this forum
