laser will only scribe a line , not cut
Hi
when i try to cut 2mm mdf, the laser will only burn a line into the board
I have a 40W laser with lightobject upgrade kit
everything works except cutting
I draw the objects in auto cad import into lasercad, all on one layer
set layer to cut at max. power, but the machine only marks the mdf
thanks
mike
thanks
mike
Re: laser will only scribe a line , not cut
Grandy
Maybe you have fallen into the trap I fell into and it is relative to cutting speed. I was only getting grooves when cutting until Marco confirmed the speed measurement. Mine was sitting at 100.00 as I didn't know what the speed measurement related to. Now I know that 100mm/s and I have to dial it back to between 1.00 and 5.00 depending on what I am cutting. Just a thought m8, worth a look.
thankyou
I will ry that
I will ry that
hi
tried slowing down the laser to 1mm/sec
it just barely cut through the 2mm mdf
this laser should cut 2mm easily shouldnt it?
What was current while running?
We're you cutting straight line or round?
Did you set proper power for the Corner Power while doing cutting?
hi Marco
thanks for helping
current = 3.3
straight lines being cut
corner power = 65%
max power = 98%
material 2mm mdf
thanks for helping
current = 3.3
corner power = 65%
max power = 98%
material 2mm mdf
i just cut some balsa (3mm) with two passes and around 25mA
it cut perfectly ecxcept not square edges ( from front of material to back )
can you manually set the current?
I'm confused here. You said that the current was "3.3", is it 'mA' or 'A' from the AC side??
Then, on next post, you said the current was 25mA.
First of all, if it was 3.3mA, of course you couldn't make cutting because current was extremely low for cutting.
But, if you applied 25mA, then it was way too much for a 40W laser tube. You're driving the tube crazy and it won't last as it rated. May be you can get 50~100hrs only. You should never drive it constant for over 16mA or intermitting 18mA
sorry
i think the meter was wired wrong way around it was showing -3.3 mA (to tube)
when i started cutting the balsa the meter showed 25mA
how do you set the current?
the laser cuts baslsa perfectly, but not mdf
forgot to say i re-wired the meter
hi
is there anyway of manually setting the current?
every cut i do, the current is different?
thanks for any help
mike
thanks for any help
mike
Are you using Laser CAD? If so on the right of your screen is a list with all the layers. Double click on a layer to open it's properties. You can choose cut or engrave and it will open the settings for one or the other. You can also set the current directly on the DSP itself but you have to go into the menu and for control mode you need to select DSP not Software. Then from the main screen of the DSP just simply press the down arrow where on the top right and it will go down and highlight each of the items on the display. Once you hit down down arrow you can select speed power etc etc and set each one of them. So recap, there's two modes DSP controls DSP, or Software controls DSP.
hi
thanks for your reply
is the current setting another word for the power setting?
thanks
mike
thanks
mike
There is MDF and MDF... Some of them contain so much junk in the bonding agent that you couldn't cut through them with a Buck Rogers Ray Gun!
Nick
Nick
you may be right nick
i have given up trying to cut it
dont know why i am struggling with the laser
was hoping marco could help , but he must be on holidays
mike
mike
