Ocen shipment is coming on Aug 8th,2016
Postby Tech_Marco » Wed Aug 03, 2016 3:44 pm
An ocean shipment is coming on next Monday (8-8-2016). Below is a list of items summary:
Machines:
1a) One(1x) 25130 (2500x1300) (8ft x 4.3ft) Tube Ride-On flat bed laser machine. White color
1b) Two(2x) 1200x900 Laser machine with power Z table
1c) Three (3x) 900x600 Laser machine with power Z table
Laser tubes:
2) Three (3x) Reci S6 130W Laser tube
3) Fifteen (15x) Reci S4 100W Laser tube
4) Thirteen (13x) Reci S2 80W laser tube
5) Fifty(50x) power Z table for the high speed XY stage PR530: 500*300, 10x 400*300
6) Twenty(20x) SL 80w Laser Tube from a new supplier: small beam spot, low threshold current, low beam divergence
7) Twenty(20x) SL 100w Laser Tube from a new supplier: small beam spot, low threshold current, low beam divergence
8) Twenty(20x) SL 130w Laser Tube from a new supplier: small beam spot, low threshold current, low beam divergence
9) Ten(10x) SL 80w Laser Tube from a new supplier: small beam spot, low threshold current, low beam divergence
10) Nine (9x) SP 80W Laser tube
11) Thirty two (32x) SPT 720mm 35W laser tube
12) Eight (8x) SPT 850mm 40W laser tube
13) Fifty (50x) SPT 1M 45W laser tube
14) Thirty (30x) SPT 60W laser tube
Water chillers:
15) Ninety(90x) LO-600 mini 600W water chiller, AC110V
16)Twenty (20x) LO-1600 1600W water chiller, AC110V
17) Ninety(90x) Mini power Z table for K40
Laser power supply:
18) Thirty(30x) 100~180W laser power supply
19) Fifty(50x) 80W laser power supply
20) Fifty(50x) 60W laser power supply
21) Fifty(50x) 40W laser power supply
XY stage:
22) Four(4x) XLE 640 XY stage
23) Eight(8x) XLE 960 XY stage
24) Four(4x) XLE 1290 XY stage
25) Four(4x) XLE 18120 XY stage
Happy shopping!
Marco ;)
Return to “Latest News”
