LightObject new laser machine design: LO-M5
Postby Tech_Marco » Mon Jan 05, 2015 10:11 am
LightObject new design - M5 Mini 40W CO2 laser machine
Feature:
-Color LO-x7 DSP controller
-M415C 2.5A high current motor driver
-Performance 47HS03 stepping motors
-500mm x 300mm useable area (bigger than K40: 300x200)
-Built in power Z table
-High speed: 650mm/s on X, 500mm/s on Y
The system will be selling in two style: DIY kit and Complete system (solid casing). It combine the high precision linear guide for the Y axis and Y wheel on X axis for higher engraving speed. The performance is solid and promised. If you're happy with the K40 performance (after upgrade to DSP), I'm sure you will be extra satisfied on M5.
Estimated price: $2,650 (retail system) or $2,450 DIY kit (no casing but aluminum frame supplied)
See M5 XY stage in test mode:
Return to “Latest News”
