Lightobject CO2 Hybrid cutter machine for metal & non-metal
Postby Tech_Marco » Fri Oct 20, 2017 8:58 am
A new shipment just arrived and with this shipment, there is a new member to join LightObject: Hybrid CO2 Laser Metal/Non-metal cutter!
With a 130W laser tube installed, it can cut through 2mm stainless steel and 4mm mild steel with Oxygen assisted. If upgrade to 150W tube, it can handle 3mm SS and 5mm mild steel
