JLD404-AH AmpH DC amp hour meter.
Postby Tech_Marco » Mon Feb 27, 2012 11:37 am
The meter is ideal to check the output from a DC sources like a wind turbin, battery or a solar panel. With this meter you can find out how much current output the sources capable to output and it can do AmpHr logging.
For example, It's good to tell whether a 12V car battery is healthy or whether is it just an 'fake' 12V box. FYI, a 12V battery with 12.5V reading from a DVM meter doesn't mean that it's a good till it can dischage enought current. Without discharging test, you can't how good of a battery.
JLD404AH-Eng.pdf
(394.31 KiB) Downloaded 1425 times
Return to “Digital Volt Current Meters”
