Capactive Proximity Sensor Switch
Posted: Fri Jun 12, 2015 12:37 am
by Pete
Has anyone got a wiring diagram for these switches please.
Cheers
Pete
Re: Capactive Proximity Sensor Switch
Posted: Fri Jun 12, 2015 2:43 am
by Techgraphix
Don't know the type you have but if it has 3 wires: Brown, Black and Blue, then connect it as follows:
Brown +V (normaly from 5 - 30V but check the datasheet)
Blue GND
Black Output, depending on your type it will switch to GND when triggered or open or even switch to +V....
Posted: Fri Jun 12, 2015 3:23 am
by Pete
Thanks for the info, going upgrade the switches when I replace the controller so trying to work out everything.
Cheers
Pete
