Dc-Dc isolated power module (6pin) connection
Postby Tech_Marco » Wed Dec 30, 2009 10:14 am
This is the latest Dc/Dc isolated power module (1205 or 1212) with 6pin. It's 2Watt and 9V~18V input. Both 5V and12V modules are sharing the same connection
lordwacky
Re: Dc-Dc isolated power module (6pin) connection
Postby lordwacky » Tue Jan 19, 2010 10:38 pm
can you please explain what the CNT and CS contacts are used for?
thanks
Postby Tech_Marco » Wed Jan 20, 2010 11:07 pm
Just leave it open as it's for specail circuit
spidysence
Postby spidysence » Thu Feb 18, 2010 2:53 pm
OK, I'm no rocket scientist...
Since the on-line schematic doesn't show it, and this pin-out is vague, please expalin exactly where each of those pins go to power the 4-1/2 inch digital amp meter.
Also, what exactly will happen during under volts?
ricklearned
Postby ricklearned » Sat Jul 28, 2012 2:38 am
Do I understand this correctly that the Vin and +Vout share a common ground?
thenar
Postby thenar » Fri Dec 14, 2012 3:22 pm
Marco, I also have the same question. A simple schematic drawing would be most helpful here. I'm not sure how it should be hooked up. I could guess but I don't want to blow it up. Apparently you sent two of them. I'm not sure why. It seems one should do the trick. It seems like this module goes with the blue meter and that it somehow is an interface between the low voltage end of the Laser Power line and the laser itself. But It's difficult to figure out how it needs to be inserted without a little more information.
-P-
Peter Plantec
Postby Tech_Marco » Fri Dec 14, 2012 4:38 pm
1,2 for input
6,7 for output
No common ground. Otherwise, there is no reason to buy an isolated power module. An amp meter need separte ground.
JAV-1
Postby JAV-1 » Thu Sep 19, 2013 5:29 pm
This thing baffles me....
Hooked up exactly as photos, all I get are 00.0 on blue meter.
Postby Tech_Marco » Fri Sep 20, 2013 11:01 am
JAV-1 wrote:This thing baffles me....
This is an "isolated" power module for the meter. If you could get "00.0", it is 100% normal. What did you expect if not "00.0"? Remember that if you have no current going through, it show "00.0". It show you reading ONLY if you connect it to a load in series
JAV-1
Postby JAV-1 » Fri Sep 20, 2013 1:40 pm
Marco....really??
When the laser fires, all I get is 00.0, must be a design flaw. I didn't get a shunt with my DSP package, had to do the crazy forum search to find out which one I needed.
I've got a fix that eliminates the shunt/isolated power supply...no worries.
Jim
Postby Tech_Marco » Fri Sep 20, 2013 2:30 pm
For the 100mA meter or 200mA, the shunt already built-in. What you need to do is to connect the Green/Blue wire in series with the laser tube to the power supply. If it read "00.0" but you got light beam, then just reversed the Green/Blue wire as the 3 digit meter doesn't support auto polarity
JAV-1
Postby JAV-1 » Sat Sep 21, 2013 5:45 am
Can you put a better diagram together for us to print and use?
Postby Tech_Marco » Tue Sep 24, 2013 9:45 am
Will draw a diagram later today
Postby Tech_Marco » Tue Sep 24, 2013 11:58 am
Update: I just draw a basic connection diagram for a CO2 laser with power supply and current meter
Link: viewtopic.php?f=16&t=1759
JAV-1
Postby JAV-1 » Tue Sep 24, 2013 1:05 pm
Tech_Marco wrote:Update: I just draw a basic connection diagram for a CO2 laser with power supply and current meter
Thank you for taking the time to do this. Too many others were suggesting so many ways to connect, I wasted time/money on a shunt.
That's where my frustration and confusion came from.
Again, Thank you.
Jim
Return to “Electronics”
