Call me a dummy or whatever but I can't figure out how to disassemble the e-kill switch so I can insert it in the hole I cut out.
I have removed the red knob, silver ring and red sleeve comes out but the top black ring that the silver ring screws in to will not budge. Is it just tight or is there something I am overlooking? Sure seems simple enough to remove parts from a threaded shaft to mount it in a hole, but not this. I just don't want to break it.
Can anyone provide some insight please? Does anyone have a picture of this thing disassembled to the point of inserting it in the mounting hole ?
Need help with the E-kill button
Re: Need help with the E-kill button
Grasp E switch as in photo. Using your thumb, push in
the white plastic clip while pulling the red top away from
the switch body.
Red top snaps back into switch base.
the switch body.
- e s2.jpg (57.46 KiB) Viewed 5243 times
- e s1.jpg (69.51 KiB) Viewed 5243 times
Awesome!!! Thank you! That's the one thing I never tried, "Pushing In" on the clip. Who would have figured...
Thanks so much again!
